Help choosing an OTA Antennea | SatelliteGuys.US
R0ss
821
2
Ayer, Ma
I live in Massachusetts. According to antennaweb the stations I want to receive are located at 147, 148 and 149 degrees with the farthest 25.9 miles. The all broadcast on uhf. The color code is blue and red. We have three HD TV's and 2 SD. Not sure if I will hook up both of the sd ssets but I should be set up to do so. The antennae will go on the roof of a two story house. One HD set is on the first floor one sd set would be on the first floor, the remainder on the second floor.
I have looked around the web and trying to figure out what I should purchase for an antenna as well as what I would need for pre amplification or distribution amplification or both is confusing as hell to me.
Any suggestions?
Ross
I assume you want the Boston stations?
If so, at that distance you wouldnt need a pre-amp. I'm in the same boat in Minneapolis. Most of my stations are on UHF so a distribution amp would help.
As for an antenna, I cant help you with that. I have an old Radio Shack VU160 that I use
Aspen Eagle DTV2BUHF 2 Bay bowtie is cheap and should work. A15-25 dB distribution amp should help if you decide to go to 5 TV sets. Multipath is going to be your greatest risk it is reflected signals coming into your antenna milliseconds off the main signal.
Yes Boston Stations
Thnaks
DXing tonight!
trees interference
