Help! can't find 99 and 103 | SatelliteGuys.US
unme
2
US
Hi, guys. I had some roof work on my house and my dish got damaged so I got a new one. I have a Slimline 3 LNB. When I reinstalled I can find sat 101 with no problem but I have been trying for two weeks to find 99 and 103. I have HD so I need 99/103. This topic has probably been asked so could someone point me to relevant threads? Any help is much appreciated.
What recvrs ?
Are your BBC's hooked up ?
put your bbc's on and see if that fixes your problems.
What Jimbo said, plus check your skew and tilt settings.
The beamwidth for 99 and 103 is much narrower than for 101. The instruction kit which comes with the dish describes the "dither" technique, which will ensure that you are actually centered on 101 and that should get you pretty close for 99 and 103 (you can then peak the signal on those, if necessary).
ESPN U HD looking good
Directv Lying about Local Channels
