Heading for Direct I think | Page 2 | SatelliteGuys.US
So is this correct?
When you add an external drive onto an E* receiver, you're adding to the total drive space (i.e. if your internal drive is 300GB and you add a 500GB external, you now have 800GB storage).
When you add an external drive onto a D* receiver, you're "replacing" the internal drive (i.e. in the example above, you would have 500GB total storage).
So is this correct?
That is true. Note that you can't record directly to the external drive from the E* receiver. It must first be recorded on the internal drive and then you can move it over to the external drive.
New install on 2/19 - What do I need to know?
