HDD 200 Glitch? | SatelliteGuys.US
HDD 200 Glitch?
blueamber
5
Hello all,
I am new to the forum and I am wondering about the GUI in a hdd200. I read that there was a starz glitch in some of them and I want to know what the exact problem is. I am currently looking into a hdd200 and want to know which ones have (or had) the glitch.
HDD200 info: It is a general instruments. Is this the best one?
Thanks to all in advance who answer!
BA:)
Hello all,
BA:)
The HDD 200 and HDD 201 are the same unit, from what I know any can have the Starz drop out problem, WWD does the free fix for the HDD 200, I am not sure if they will do the free fix on the HDD 201 that was intended for Star choice, also if I am correct the problem is only with the 922 and not with the other 4dtv models but not all the HDD's have this problem.
I thought it was HBO-HD glitch with the HDD-201 and HDD-200's weren't affected:confused:
Shows you how information gets confused as it gets passed on after a while.
If you end up with one with the glitch, get a hold of ATS Electronics and they will be able to get it corrected. Cost, I'm not for sure, seem like I have read that it would be fixed for free.
ATS will not do the free fix, Motorola has WWD do the free fix for the Starz drop out problem.
C Band/KU FTA
Best Brand of Dish
