HD Channels, Low signal Sat 129 | Page 2 | SatelliteGuys.US
As this is not really a follow-up to your original question, it should have been a new thread.
A "DPP separator" will allow you to use only a single coax from the dish to a dual-tuner receiver/DVR.
Using the correct terminology is imperative. Tuner refers to a device inside a receiver. It does not represent the entire box (known as a receiver or DVR as appropriate).
You might benefit from a wander at http://www.dishuser.net .
What kind of seperator would I need so wouldnt have to run two coax from switch to receiver. Currently I have two coax running from switch to each tuner on receiver. But I want ro use one of tje coax for something els.
What "something else"? If you want to put your antenna onto one of those same cables, that can be done with a pair of diplexers. But to answer the question, and unless I'm sorely mistaken, you have a new 500+ dish with a DPP switch inside. You can put a separator on the cable you want to use for your 722 and the stubby cables feed both tuners.
PTAT - dual recordings
Preparing for the Hopper installer.
