i do have one more question... i am wondering if directv will activate an H24 box for things like camping and tailgating. or will that be like trying to get blood from a turnip???
If you add it on to your already existing account they will .... then You take it camping or wherever.i do have one more question... i am wondering if directv will activate an H24 box for things like camping and tailgating. or will that be like trying to get blood from a turnip???
ok. i have the genie 54 but i was also gonna buy another dish and mount and take it with me i wouldn't even hook it into my home systemIf you add it on to your already existing account they will .... then You take it camping or wherever.
Making sure that your home set up doesn't include the HS17 Server, as the H series won't work with the Server set up.
My advice would be to connect it at home and make sure it works and is active before hand, just makes it easier in the long run ... also, when you set it up at home, you'll be setting it up using a PI (21 or 29v) so it will see the LNB right away at home.ok. i have the genie 54 but i was also gonna buy another dish and mount and take it with me i wouldn't even hook it into my home system
ooppss yea i would want an HR24 instead. i don't think there is an H24 boxMy advice would be to connect it at home and make sure it works and is active before hand, just makes it easier in the long run ... also, when you set it up at home, you'll be setting it up using a PI (21 or 29v) so it will see the LNB right away at home.
If you use a PI (21v would be fine) at the campground, it will be much easier transferring back and forth ... ( the set up without the PI can be difficult when chamging back and forth).
Btw, are you sure you don't want a HR24 instead ?
If you go with the dome style, it only sees the 101 Sat ... That at the moment is mainly SD stuff, if thats OK.ooppss yea i would want an HR24 instead. i don't think there is an H24 box.. i am thinking of going with a dome style dish also its portable and automatic... will DTV have those boxes or am i gonna have to shell out some $$$ at solid signal??? i
Yes, that would be easy ...I'd hate to use a DVR for camping/tailgating because of how much longer they take to boot up (RV's with constant inverter power system excepted).
I'd personally want a H24 with a b-band converter and a conventional non-swm SL3 LNBF. Simplest setup.
I'm sure that, that is what ATT/D* would want to happen.Another reason why he might prefer the H24 over HR24 is because he probably either has a deactivated one laying around they didn't want so it is free, or he will have to pay Directv for it and the H24 will be cheaper to get than the HR24. I doubt they are offering anyone a "free upgrade" of adding another HR24 - they'll want to add a client to an existing Genie since that's cheaper and is using hardware that isn't rapidly approaching 10 years of age.
Limited time offer
