Grease a Skyvision actuator? | SatelliteGuys.US
orthoclipse
27
Any owners of a Skyvision Ultra Power dish mover, do you apply grease to this dish mover?
The mover looks very similar to the Venture branded ball screw (Maxi Ball Srew) model which I previously owned. This had a special inlet port which could be connected to a grease gun. There's no such inlet on the Skyvision model and lately I have noticed creaking noises from the actuator.
Any suggestions welcome.
h**p://www.skyvision.com/store/mi1010028.html
If you don't have grease fittings the only thing you can do is remove the weather boot and oil the arm. I have a weather boot on my Thompson Saganaw 24" arm and never did anything except grease the gimble brackets twice a year. It's been in use since May 1989 with no problems.
Thanks for the reply.
I took a chance and inserted grease through the drainage holes and the creaking stopped after the grease worked its way through the actuator .
Problem with VCII+ module in second hand DSR922
Birdview Hunting Society humor
