Yes, it is. Now I'm regretting the decision of not ordering two SD-DVRs. Do you think that if I call them and ask to replace one of the SD receivers for a SD-DVR I will get another R22? I understand that it will cost me another $99 but if they come and install it that's worthy. Also, let's say they say yes, will they install a SWM-16? I'm maxed now with a SWM-8.
Yes jaj1701, you warned me.![]()
I wouldn't like your chances of getting another R22. They are rare and hard to find. You should consider yourself lucky that you got one (and making me jealous :rant:
For the SWM-16 they will give one but I don't know if they will charge you for it. When I got my whole home solution they initially brought just one SWM-8. I tried to tell them I would need a SWM-16 since I have 5 DVRs. After they realized it wouldn't work they had to go back to their warehouse and get the SWM-16 plus another SWM-8. 4 lines from the dish feed the two SWM-8s which then both feed into the SWM-16. Since it was the same installation there was no extra charge. Yours might be considered a different install and therefore might incur charges. But I don't know for sure. Maybe stonecold can answer this better.
