Geosat pro 1.2m dish u-bolts | SatelliteGuys.US
Not to state the obvious , but . ..
Did you contact SatelliteAV about the replacement bolts?
He's on here a lot, and very helpful.
Failing that, what about all the usual hardware stores?
Around here, we have Ace Hdwr, Home Depot, Lowes...
Assuming the local stores are a bust, that leaves an internet search.
There are industrial hardware suppliers near every large city.
I have been to some stores who will sell you any sort of bolt you can imagine, made from any material, and in pretty much any size. ;)
Some of 'em must have web sites...
....and once you replace your bolts, maybe you'll comment on the dish.
Sure looks attractive (I just peeked at it again, thanks to your link).
I'm curious as to why you need to replace them. On mine, I had trouble with the Dish Ubolts hitting the coax connections on the GS-120 motor. So, I cut my bolts off to prevent it.
Al
Dish U Bolts
In Africa we use U bolts which are used for motor vehicle exhaust systems.
Al
my got stripped out.I have the same problem with the bolt hitting the coaxial also on the GS-120
We can supply the U-bolts. A trip to the local hardware store would probably be faster and cheaper. We can't compete against a Lowes including the shipping cost ....:(
Give us a call if we can assist!
Switch safety
