It's possible but I don't think it'll be a good idea to attach anything to these aluminum ribs because they're easily damaged.
SatelliteAV said:If the ribs are too light weight, attach an angle iron arm to the ring and move the attachment point out one, two or more feet... The jack appears to be able to support at least a few additional feet of offset. You wouldn't believe the difference this modification will make in increasing the aiming accuracy and lifting capacity. I would guess that your motor would start reliably landing on the satellites!
I did that to a dish and it worked. Stick welders are fabulous LOL
More photos of my KTI actuator mount.
If you want to experiment before welding, buy a few electrical splice plates SuperStrut, 3 Hole, Flat Splice Plate Fitting, 5-3/8" x 1-5/8" x 1/4", and a few 1/2" nuts and bolts.(I got mine at Home Depot) Then play with the positions. For me I got more range and less stress on the actuator.
johnnynobody said:The nice thing about where the actuator is mounted (per vendor instructions) is that it gets the dish into position much faster than my Paraclipse.
Pick one.....
1. Speed
2. Accuracy
Pick one.....
1. Speed
2. Accuracy
I once alluded to pulse-modulating the motor power, but nobody seemed to care.Pulse width modulate the power to the motor.
When you are within say 1-2 degrees of target, you drop from 100% to around 50%.
And when within around .5 degrees, cut to 25%.
Limited time offer
