Fortec Star Lifetime Classic NA | Page 2 | SatelliteGuys.US
Pipe
I've had a few receivers do this (whne you scroll, the motor moves)
My Coolsat does that too (along with the Captiveworks)
I'll play with Channelmaster in the n ext day or so to see if there is a way. You might have to do like Coolsat does is upload it via the loader then open it through Channelmaster
I've had to use the multi step process of using the FortecStar DnUpMan program to "upload" the data to the pc, then import to ChannelMaster as "Fortec CDF format".
Work with the channel data, export to "CDF" format then "download" the channel data again with the DnUpMan program.
It seems long but works well and beats using the remote to do multiple updates.
Black Screen On One, Clear On The Other
wngs on g-10 what's going on?
