First problem with HR 20 | SatelliteGuys.US
sguest9
SatelliteGuys Guru
127
5
Athens ga
I have mine hooked up HDMI cable. Get up today and all I get is snow. Changed to component and get a pic. anyone else having this problem. cant try reset the game is on.
Yes that is happening with the HDMI cable. A lot of people are using components to get around the prob. I heard on DBStalk that it will be in the first update to fix this issue. They are all talking about it over there.
I have had that problem a few times, have been able to fix by turning off receiver then unplug/plug in hdmi cable, then power on. annoying but at least it works.
Free HR20 in Atlanta
8 ports on multiswitch..need 9
