No, it's been out a little over 2 years. I got one of the first ones.
Feb 1st 2006 I believe. I was about two weeks behind you.
I picked up the Tripplite from Costco, it was $99. I use it on my 622 with 50"LCD and Yamaha 861 and I have one on my 722 with 40" LCD. Have to protect the valuables.
How long can all of those devices run with the tripplite unplugged? Probably doesn't matter much with your setup. I got mine so it will last long enough for me to shut down the DLP so the bulb doesn't overheat.
No one has asked yet is there a power inserter in the system? Could it be that this system was installed w/o one and it is pulling to much current from the 622's and burning out the power supplies this way.
Could someone recommend a couple of reliable and rugged UPS' ?
Thanks,
Darin
Limited time offer
