FFDShow and MyTheatre | SatelliteGuys.US
cracklincrotch
1,026
Halifax, Nova Scotia
Anybody know why I can't get FFDShow to show up as a video decoder in MyTheatre? Works fine with DVBDream (other than stability issues with DVBDream itself, not FFDShow) It is installed. Tried reinstalling it.... Out of ideas.
Take a look at the MyTheatre forums, search "ffdshow", I can't get it to show up in Mytheatre either, although there are some who can. There are some hints on that site that apparently have helped some people.
I never got FFDShow to appear in the autograph selection menu. No one has been able to explain the problem, or show how to fix it. The work arround is to build a graph with FFDShow and then use the graph.
The program that I use to build custom graphs is graphmaker. Just save the custom graph in the graph folder in MT and then select it from the graphs menu.
Will a CoolSat support S video and RF at same time
What is the best HDFTA box out there right now?
