Geez, I'd be headin' out to beat you to it, if I were anywhere close!
Do you know what the heck you've got here??
a gold mine and about an hours drive
will probally jump on that and store it till i move to somewhere more bud friendly
Actually, without expensive RF probe and lab equipment you'll not know for sure what position/size of the 'ball', or its shape, or phase shift......
A mold machined with CNC machinery with a plus or minus 0.001" accuracy only produces an FRP or stamped metal dish rated as 50% efficient by most manufacturers. Some of the Oriental manufacturers are now claiming 75% efficiency with their stamped dishes, but the "old" rule of thumb was 50%.......One thing worried me and I did ask nelson - parabolic curve precision......
Bending the struts to any degree of accuracy is hard enough, but welding them together accurately is another problem all together.......if he controlling only radial directions, it wouldn't be enough......
Diffusion equals signals out-of-phase that cancel out in-phase signals drastically reducing efficiency or a focal point three feet further out than it should be........flat segments will create unwanted diffusion......
Electrically, the big dish is now really a fraction of it's physical size.......reduce efficiency of the big dish.
If you wish we go into more deep details - the light's wavelength is WAY out for measure 5 GHz RF focal size. I emphasized the mentioned "ball" characteristics - and would tell you again: you can't get them by using flashlight.Until the surface is dulled or painted the focal point is visible at night or in a darkened room by shining a floodlight boresighted on the dish.
I'm see the issue as reflection in other direction not to focal point, if you circular profile approximated by flat segments in the dissection.A mold machined with CNC machinery with a plus or minus 0.001" accuracy only produces an FRP or stamped metal dish rated as 50% efficient by most manufacturers. Some of the Oriental manufacturers are now claiming 75% efficiency with their stamped dishes, but the "old" rule of thumb was 50%.
- I'm talking about same effect.Electrically, the big dish is now really a fraction of it's physical size.
......the light's wavelength is WAY out for measure 5 GHz RF focal size. I emphasized the mentioned "ball" characteristics - and would tell you again: you can't get them by using flashlight.....
Using Sun during sunny day will be better for the test.Can you explain why a flashlight or floodlight would not work??? I was going to try and shine my car's headlight on a DN 500 dish and see if holding a black piece of craftpaper in front of the lnb to see if it show a round spot of light as a focal point. I would love to hear your opinion.
mikelib
I beg to differ with your opinion, which is not founded by science or engineering, but a parabolic surface is not frequency dependant. It does not know if it's reflecting mircowaves, lightwaves, or soundwaves.....It just reflects what hits it. In its geometry, any "wave" (electromagnetic, sound, or light) reflected travels exactly the same distance to the focal point, arriving in phase with all the other "waves".
In short - different length of waves......
Limited time offer
