I'm getting used to my drive now... and it is rapidly filling up
no problems other than noted...
I've updated my spindown to "Never" and the drive is always "available" now. Wasn't aware of the number of moves restriction.... I must have missed where this was posted....Remember that currently you can only move programs three times before they can no longer be moved.
Don't want to sound like I'm arguing, just want to point out that the Seagate FreeAgent Desktop drives have a 5 year warranty and use Seagate SATA drives (ST3500641AS 500GB in my case) which has a MTBF of 300k hours (a little over 34 years). Going the conservative route, if I still have this drive and a ViP622 in 5 years, I'm not nearly the videophile I thought I was!It's best not to leave them on 24/7 anyway. Turning it on when you are actually going to use it probably will avoid the glitches.
Once it's gone to sleep, it will "wake up" and allow me to view programs, but it will not allow me to move more into archive.
To "wake" it, I go to "Manage Device", and nothing is there. I then exit back to the TV, go to Manage Devive again, then the archived programs are available for playback.
The playback will start successfully, but then when hitting STOP, nothing happens, and I have to power off the 622 (don't have to reboot, simply hit the power button on the remote).
Even after doing all this, if I go to "Send to device", it looks like it's starting to transfer, then goes to the screen saying it can't be done (typiing from work so can't remember the exact wording).
Anyone else experiencing similar problems? It all works perfectly by unplugging the HDD and then plugging back in. Not ready to change the power setting to "always on" yet, as I really don't use it that much and it's more of an annoyance than anything right now (and hopeful that Dish will figure out how to wake it up!)
I've read that same thing. By my interpretation what is happening is:The only bug I have read that is most likely a real bug is the one person who says he cannot delete programs from his external drive.
can I ask what ext hd you have?Once it's gone to sleep, it will "wake up" and allow me to view programs, but it will not allow me to move more into archive.
FYI - After having turned off the spin down on the Seagate FreeAgent Desktop 500 I have, My issues have all but disappeared.
- Issue with the initial access to the drive saying it needs activation - GONE.
- Issue with the drive being detected but no programs listed - GONE.
- Issue with the drive not being able to delete programs - GONE.
- Issue with the programs being moved from archive to the PVR staying on the drive - GONE.
I am still on L441, but the only change I made was the drive spindown. I am a happy camper now! (Especially since my wife's crappy episode of BB8 is gone from the drive!)
By the way, the OTA 35 minute file is 4800 and the Dish feed of the same channel same time was 2395. 50% Smaller then the OTA.
(1) Moved the external drive to my (Windows XP) computer; using disk management function, deleted partitions from the PVR formatting, then installed one NTFS partition with quick format from windows, gave the drive a temporary letter (I, J, whatever)...
You did not need to reformat the drive from the 622 format to PC format just to turn off the Sleep Interval.
Thanks for the clarification, which I suppose means that FreeAgent tools can recognize these drives even if Windows' Drive functions do not. I reformatted BEFORE installing the tools, so I never tried. Without reformatting, the process is even simpler, and I guess would preserve any archived programs on the drive one doesn't wish to lose. No one with one of these drives should be deterred from changing the sleep function because of feared complexity.
The only remaining "bug" I can identify -- which I suspect involves DN's software rather than being unique to the FreeAgent Seagates -- is that when playing HD programs from the external drive, especially after fast-forwards -- they don't RESUME where they left off, but someplace much earlier in the file. This doesn't seem to happen for SD recordings.
Limited time offer
