EtheWi Wireless-G Bridge | Page 2 | SatelliteGuys.US
Yes.... tried the cables included, tried other cables. Like I said, the bridge will work fine connected to a desktop or latop.....just doesnt work when connect to my Dish 222k or 722k. Even tried a Netgear router vs. a Dlink router.
So I finally took an old wireless router, shut off the wireless, connected the bridge to the WAN port, connected the ethernet cable to the LAN port of the router and the other end to the Dish Receiver and voila....it worked! So now I'm using the bridge as the wireless feed for a router and the receiver is plugged into the router. Works for now until I can find another solution.
I really think it is something with the way the EtheWi is communicating with the Dish Receiver........
when you say you shut off the wireless, on what item did you shut it off? the router you useing as a bridge?
922's EHD's to be DISABLED tonight.
AAD Distant Nets
