Error code 60 | SatelliteGuys.US
Error code 60
csloan1981
73
5
Arkansas
I have a error code 60 on a joey. Tried to reset the network rebooted both hopper and joey. Hopper 3 and 2 joeys. Hopper works and one joey but the other joey doesn't?
Sent from my iPhone using SatelliteGuys mobile app
Can't remember off the top of my head. You can try and unplug power and Rg6 cable, then hook the cable back up then power. There is a way to link from the settings on screen. I would have to look it up
Sent from my SAMSUNG-SM-T337A using the SatelliteGuys app!
Try this: On the Joey with the error code, Menu, Settings, Diagnostics, Whole Home, arrow over to the Hopper 3, Press Select and then press Select again. If it wasn't linked, that should relink it.
EHD Failure
PAC 12 Network?
