Enhanced Hardware in the original Joey? | Page 6 | SatelliteGuys.US
LOL. Whenever Scott gets us the new Super Joey wiring diagrams maybe you can figure out how to add it to the mix. I would like to keep all my Hoppers and swap the Joey out for a Super Joey if there is any advantage.
Well, my guess is you'll need another feed from a DPP44 (not sure if SJ will like being behind a power inserter.) If it can't be behind the power inserter then you'll need another DPP44. A diplexor will be needed to hook the SJ to a client port on the node.
Sent from my iPhone 4S using Forum Runner
I'm still deciding whether I want the SJ or just a plain J when I upgrade. Leaning toward a plain J.
Upgrade from what lol? With 4H/1J do you need more tuners?
I'm thinking of swapping a J for an SJ perhaps. I've got 2 HWS/2J with 2 44s, a 33, and 2 duo nodes, so rewiring wouldn't be an issue. Plenty of open space. Don't really need more of anything but I like to tinker with things.
I like to tinker too. Got a spare DPP44, diplexers, and splitters. So I am ready to experiment and test things out. But, I would like for all Hoppers and Joey to be able to see each other somehow. More tuners the better.
Why do you have 2 44s, a 33 and 2 duo nodes for your setup?
Full hopper integration is something I've given up on I guess. It would be nice, but for now switching the MBR joey between hoppers works fine. Hopefully in the future they'll perhaps work it out. It's not a deal breaker either way. I've honestly got zero complaints with my system, but even if I did, the fella that installed and services it lives in the house.......
lol it's a bit complicated. My neighbor has dish but really didn't want the dish on the house. They are price shoppers and I don't expect them to have it after the 2 years is up. So I installed the 44 and had them running off port 1 for their 722. Ran burial back out of the basement across the lot line. Then I read that bridged nodes were "unreliable" but wanted to see for myself, so I put in another switch, and have 2 duo nodes each with 1 hopper with the power inserters in my basement. Neighbor has the 722 off a 33 now just so I know if the PI ever goes out more or less. On top of that my joeys are running off ethernet without coax, and I have 2 HIC's in the system as well.
All in all it's a bit ridiculous and definitely overkill, but I've had zero problems with it at all, and the install is neat and clean. I wouldn't have it any other way.
Liked just for the craziness of it all. :)
LOL. I figured out why my Joey felt so "sluggish." I was using an older 20.0 remote and the batteries were nearly dead. D'oh! It's a hell of a lot more responsive now. That being said, I'm still looking forward to the newer Joey hardware. I will still be swapping out. So far I just can't see where I need a SJ when I already have four Hoppers and a 722k.
Dish Investors Ignore Ergen’s Failures as Spectrum Value Grows
Finishing Basement Help w/ Wiring For Dish Needed
