EA - Moving from Dual Dish Solution...Question. | SatelliteGuys.US
jetsetter
59
Well - Here's the background - I got a call from Dish a few days ago, saying that they are noticing that there's a signal problem on my setup - which was right, as I had noticed lost connection messages lately as well - but not bothered enough to call...
Nice to hear that they were being pro-active. They scheduled a free visit for today. When the tech showed up, he also noticed that on my 119 and 110, I had weak signals. When he looked at the dish setup outside, he thought it was the tree that was blocking the signal...
He gave me two options - Trim the tree (not something I was interested in) or move the second dish to another location - not something I was keen about.
I asked about getting the EA install. He called his Mgr, who said that it will cost me to upgrade. I suggested we call Dish directly and see if they would be more receptive... Well, guess what - on the first call - I got lucky. The tech explained to them the issue and said that Customer would prefer a single EA dish setup and they said OK! They are scheduled to come back on Thursday to install that....for no extra charge. The tech did not have the 1000.4 dish, so the rescheduled visit.
So, my questions: Is there a downside to this, that I may have overlooked?
I currently have a Dual dish setup (Dish 500), pointing to 61.5, 110 and 119. I have the HD's, locals and International programming. I have three receivers, 722 (w/smartcard), 622 (no smartcard) and a 211 (w/Smartcard). All these smartcards were installed over the last month.
BTW, I am in Tampa, FL.
Your international channels will likely require a 110 wing dish plugged in to the input of the ea lnb, but that allows you the freedom to put it in the clear of that tree.
His internationals will stay on 61.5 for now. But that does pose another problem when/if Dish moves all Internationals to 118. Then you'll be back to two (big) dishes again. You might want to give the original idea of moving the 119/110 dish a little more thought. (or trimming the tree)
But since he is in Tampa I dont know if 129 would work for him anyways so once they move his Int'l chanel to 118 the options are
-D500+ and a 2nd dish at 61.5 for HD
-EA dish and 2nd dish at 118.7
Thanks for the feedback guys. It seems like, my best option is my current setup - with moving one of the dish so it has a clear line of sight and not to get a EA 1000.4 Dish setup. (grass isn't always greener on.......)
I just want to confirm, before I call Dish and start making changes to their order...
Thanks again.
Some questions about dvr functions
Moved My 211 Receiver to bedroom and no power?
