DVR models compatible w/DPP33 system | SatelliteGuys.US
BUD_n_Sons
37
31
South West Michigan
Is there a definitive list of what works with what?
I need to replace a Hopper & Joey and am getting conflicting answers.
I run separate 40" dishes into a DPP33 & SoloNode.
Wish I could buy a 612 or 722, but they're obsolete anyway.
Is it only the Hopper3 w/16 tuners that require the LNB / Switch upgrade?
Thanks, in advance... Kevin
With your configuration of dishes and a wish to go to a Hopper 3, you would need a DPH 42 switch or a LNB change to Hybrid and change out the Solo Node to a Solo Hub. Now, if you wanted to change to, say, 211Ks, you remove the Node and bring both coaxes from the receiver locations to the DPP33...
Reactions: pattykay
Problems anybody have a fix??
I have a question about japanese international package
