DVR 921 and 1000.2 w/ DP44 Not Picking Up 110 129 :( | SatelliteGuys.US
Deekay213
12
I have yet get sat 110 and 129 on my DVR921 in the beginning when i first set up my dish all i got was 110 sat. But after i set up my Dish Pro Splitter and power converter i get Sat 119 at "115 strength" but no 110 and 129. When i perform a Check Matrix Switch it tell me that 110 and 129 have Good Connection but no signal. At first i thought it was my Switch DP44 but every time i change the LNB Port with the 119 cable it works fine on any Input port. I doubt its my Satellite since its new... Is there a certain way i have to point the dish since i get a great strength on 119? Im stumped guys... :mad:
Check the skew on your dish.
Also check which lnb is receiving 119, you may be off by 10 degrees.
Do you have multiple receivers, if not why the DPP44? The 1000.2 will support, I believe, up to 3 receivers (maybe 2) without any external switches.
211 program guide needs constant updating
NBA tv.Channel 402-new hd channel??
