DVBWorld 2104D DVB-S2 HD USB BOX and Windows 7 | SatelliteGuys.US
Babadem
2,306
177
MA
I just upgraded to Windows 7 from Windows XP, and I'm finding out that my DVBWorld 2104D USB box is not compatible with Windows 7. Anyone knows if there is a Win 7 update for the the DVBWorld 2104D USB receiver?
Babadem said:
Anyone with a solution?
Perhaps a dual boot system XP and 7. I have no idea about the drive I assume u have searched hi and low on the search engines?
There is a special compatibility mode in Win 7 to use WinXP drivers for hardware. I have used it for built-in sound cards on some older motherboards. It's been awhile and I'm not exactly sure the procedure, but it's there. It might be worth a try.
Those were the settings I tried first. It would always crash each time i launched the Application. :(
Sorry, can't help you with the DVBWorld 2104D.
Have been using a DVBWorld 2104C on Windows 7 for quite a while. (using 'Device Manager', it displays: 'Driver Date 4/23/2010' and 'Driver Version 3.0.0.1')
Another option to try is getting virtualBox (virtualbox.org), then load XP in a virtual machine, select a folder to share between the Win 7 system and the XP..., then watch recorded stuff from Win 7...
Can you upload the Driver to the Download section of satelliteguys?
MicroHD to be given away tonight on Satellite Nation
We have a nother new bird: Amazonas 3 from Hispasat.
