dvb world dvb-s2 | Page 4 | SatelliteGuys.US
dvb world dvb-s2
thanks a lot
I uploaded file to your server.It is called dvb-s2.rar
i have downlaoded it and analyzed the tsdata!!thanks a lot!!:D but i also need H.264 TSData!!
the ts data information:
PAT Version Number: 1
Transport Stream ID: 1 (0x0001)
NIT: 131.0W 1.070 GHz Vertical 30000 3/4 8PSK (DVB-DSNG/Turbo/DVB-S2)
PMT PID 16 (0x0010) - Network
PMT PID 848 (0x0350) - Program 41 Bravo
On Table_ID: 0x42 (current mux)
Service Name: Bravo
Provider Name: NBC Universal
Transport Stream ID: 1 (0x0001) 131.0W 1.070 V 30000 3/4 8PSK (DVB-DSNG/Turbo/DVB-S2)
Program Number: 41
PCR on PID 849 (0x0351)
PMT Version: 1
Service name: Bravo
Stream Type: 0x02 MPEG-2 Video
Elementary Stream PID 849 (0x0351)
Stream Type: 0x81 AC-3 Audio
Elementary Stream PID 850 (0x0352)
Elementary Stream PID 851 (0x0353)
Stream Type: 0x86 User Private
Elementary Stream PID 852 (0x0354)
Descriptor: Maximum Bitrate Descriptor
Maximum bitrate: 2244300 bytes per second
Descriptor: Multiplex Buffer Utilization Descriptor
Bound Valid Flag: 1
LTW Offset Lower: 180 Upper: 180
Descriptor: Registration Descriptor
Format identifier: 0x43554549 (CUEI)
Descriptor: CA Descriptor
CA System ID: 4112 (0x1010) Tandberg Television
CA PID 924 (0x039c)
PMT PID 880 (0x0370) - Program 42 USA
Channel 42
Service Name: USA
PCR on PID 881 (0x0371)
PMT Version: 1
Service name: USA
Elementary Stream PID 881 (0x0371)
Elementary Stream PID 882 (0x0372)
Elementary Stream PID 883 (0x0373)
Elementary Stream PID 884 (0x0374)
Bound Valid Flag: 1
CA PID 860 (0x035c)
PMT PID 912 (0x0390) - Program 43 SCI FI
Service Name: SCI FI
PCR on PID 913 (0x0391)
PMT Version: 1
Service name: SCI FI
Elementary Stream PID 913 (0x0391)
Elementary Stream PID 914 (0x0392)
Elementary Stream PID 915 (0x0393)
Elementary Stream PID 916 (0x0394)
Bound Valid Flag: 1
CA PID 892 (0x037c)
PMT Channel 65534
Service Name: dl service
Provider Name: TTV
Transport Stream ID: 1 (0x0001) 131.0W 1.070 V 30000 3/4 8PSK (DVB-DSNG/Turbo/DVB-S2)PID 100 (0x0064) - Program 65534 dl service
Service Name: Bravo
Program Number: 41
PMT Version: 1
Service name: Bravo
Bound Valid Flag: 1
CA PID 924 (0x039c)
Channel 42
Service Name: USA
PMT Version: 1
Service name: USA
Bound Valid Flag: 1
CA PID 860 (0x035c)
PMT Version: 1
Bound Valid Flag: 1
CA PID 892 (0x037c)
PMT Channel 65534
Provider Name: TTV
None of the channels in the file I sent you are H.264.Do you need me to upload
a H.264 captured mux.It seems the dvbworld box will now play an H.264 feed but will not play a DVB-S2 Mpeg 2 HD feed.
Service Name: Bravo
Program Number: 41
PMT Version: 1
Service name: Bravo
Bound Valid Flag: 1
CA PID 924 (0x039c)
Channel 42
Service Name: USA
PMT Version: 1
Service name: USA
Bound Valid Flag: 1
CA PID 860 (0x035c)
PMT Version: 1
Bound Valid Flag: 1
CA PID 892 (0x037c)
PMT Channel 65534
Provider Name: TTV
I uploader a DVB-S2 H264 file to your server it is called DVB-S2H264.rar
Are you still
trying to fix the DVB-S2 problem with the usb dvbworld S2 box?
yes, i still trying to solve some bugs, but u upload the DVB-S2H264.rar has some error, i cann`t unzip the file, so i cann`t analyze the data, pls upload again ,:upthank u very much!!
I am uploading the file in a zip file.
when i unzip the DVB-S2H.264 .rar file, the rar tool show the picture, so i think the file has been wrecked,so i cann`t analyze the data, pls upload again ,:upthank u very much!!
I uploaded it as a zip file also.It is on your server.
the file has been uploaded
again.
again.
i have downloaded the dvbs-2H264.zip file, but i analyzed it ,the tsdata is the same old file. it is DVB-S2 MPEG2 format video data. can u upload some DVB-S2 H.264 format video data? thanks your help again!!
The DVB-S2 H.264 format video will play with your Dvbworld software.I am not having
anymore problems with the other DVB-S2 channels.
This solved the problems one "feature" or bug of the dvbworld software is that on channels that have a CA descriptor set the software assumes those channels are encrypted and seems to not even attempt render the video and audio of those channels (perhaps because doing so on a channel that actually is encrypted might crash the video decoder if it's not well behaved). The signals I was looking at on G14 have a CA descriptor, which would normally indicate they're encrypted, but it seems they're not encrypted, or at least not at times and of course this is likely a temporary condition. Anyway, I think you may find that if you select "edit channel" in the dvbworld software and then change them from "scrambled" to "FTA", you'll likely be able to get video on these channels. If after doing this you still don't get video you may have some other issue like a codec issue.This solved the problem.My thanks to Member Stefan for figuring this out.I have no problems getting the DVB-S2 channels now..DVBworld the file on your server called DVBS2H264.dat is a H.264 DVB-S2 feed.Your software will already play this kind of feed.The software works fine once you edit the channel CA descriptor.
DVBWorld new Version software has released
:up
thanks your infor , now we update our software in our website :
http://www.worlddvb.com/html/softdown.htm
pls download it , then install and test it , we add some new functions and solve some bugs:
1.Add a function to select decoders.
2.Fixed the bugs that fail to scan high symbol rate(30Msps) DVB-S2 channels.
3.A warning about "wincore.cpp".
I have been following this thread and it seems like the unit works and I would like to buy one but I have not been able to find a re-seller. Can someone point out where I could buy of these units?
Thanks!
Captive Works
spa
