Dual Outptu Cband LNBF? | SatelliteGuys.US
equant
265
Tucson, AZ
I've got an old Ku/C band LNBF. I'd like to replace it with a setup that can let me get both H and V C-band polarities at once. Is there anything out there for me? I'd like to keep Ku, and even have the same feature with Ku, but I'm also willing to lose Ku all together if necessary.
Thanks.
Equant -- I wasn't aware that there were any old C/Ku-band lnbfs made that did not automatically select H and V polarity.
Both SatelliteAV and Sadoun sell combo C/Ku band lnbfs (for large C-band dishes).
Not to be confused with Circular/Linear Ku-band lnbfs such as the Invacom Quad LNBF QPH-031 (for smaller Ku-band dishes).
Well my current LNBF uses a servo to control polarity. It's pretty old and I'd like to replace it, and what I'd like is a setup that lets a non-motorized 8' dish be shared between two TVs at one time. In other words, so someone can be watching a vertical transponder while someone else watches a horizontal transponder.
I guess the GeoSat Pro does what I want, but are there any dual ouput Cband LNBs and Kband LNBs that I can attatch to my (or any) feedhorn?
For both C and Ku bands, you might search the forum for: "orthomode" or "Bullseye II".
It'd involve four stand alone LNBs bolted to a big cast feedhorn.
As noted, it gets pretty expensive, and the cost of the individual LNBs adds to it.
There are several solutions for dual-output C-band only.
The SatAv C2 mentioned above is probably the least expensive.
There are some more traditional feedhorns that take two standard LNBs, and their price is between $60 and $100.
There is maybe one acceptable for C and Ku, with single output, but as that isn't what you want, we won't go there.
107.3°W Anik F1R C update
GBox V4000 with Polarator control
