Drake HEMT ku lnb dsr 922 | SatelliteGuys.US
vassho
71
I have what seems to be a older Drake KU LNB its a HEMT only other thing i can read off it is +15-24VDC output 950-1.450 and whats real faint is either NP 1.8 or NF 1.8 as the label is worn
Its rather rectangular around 5 inches long pretty stout piece and well made for sure
I know it will work but not sure about the quailty i will get from it
it came with a corotor i bought
the c band temp is 60 but i have plenty of new C band LNBs so i dont have a issue with changing C band LNB, but i dont have many KU lnbs besides this drake and a few LNBs from new Huhges net systems which i can take off the transmitters and use the LNB off one of those if needed
The Drake looks healthy and looks like a fine KU LNB but again i am concerned about quailty with the dsr922 and wondering if the drake Hemt would do me right
Thanks again
some of those "old" LNB"s work really well. I use to use a 35K temp one and it gave me better results than the 17K One I had used
I say try it out..worse thing that happens is it doesnt work good and you replace it
ku lnb dsr922
photos of vintage corotor throat and calamp centerline feed
