DP+44 question | SatelliteGuys.US
DP+44 question
chicagofilms
329
If I get a DP+44, can I use a single line from it with a DP splitter to connect a 510 and a 811?
I have one of each right now in my HT & I switch the satellite cable between the two depending on which one I want to use.
Cyclone said:
No, The DP Splitter only works with Duel tuner receivers.
The DP Splitter has nothing to do with this question. That part has a totally different purpose in life.
You mean the DP Separator which is what is used with a DP+ Switch or LNBF to allow a dual-tuner receiver to run both it's tuners from a single feed cable.
Any news on 269??
Anyone thought about the future of AMC-2
