Does Directv use splitters? | SatelliteGuys.US
stellar832000
171
San Antonio
Does Directv use separators?
I really don't have any knowledge of installation so I have a question...DVR's require two satellite inputs to function (tuners 1 and 2) with Directv the installer would always run two seperate cables from the switch to the DVR, but with Dish they run only one and then separate the wire just before it gets to the DVR to create two seperate inputs...is this right? why doesn't directv do this? Or is it just a matter of the installer?
The way the two systems work (DirecTV vs. Dish Network) is totally different. In a nutshell splitters will not work with DirecTV.
You CAN use splitters with DirecTV if you have one of the new SWM LNB's or a SWM8 module, that's the only way you can use splitters. If you're a new installation and have between 5 and 8 tuners being installed (like two DVR's and one non-DVR or four DVR's) there's a good chance that you would get a SWM LNB for the install. If you're already installed your only option if to purchase your own SWM LNB or a SWM8 switch, the SWM8's are available via Weaknees a site sponsor here.
I really don't have any knowledge of installation so I have a question...DVR's require two satellite inputs to function (tuners 1 and 2) with Directv the installer would always run two seperate cables from the switch to the DVR, but with Dish they run only one and then split the wire just before it gets to the DVR to create two seperate inputs...is this right? why doesn't directv do this? Or is it just a matter of the installer?
DISH has Legacy and Dish Pro LNBs neither of which is compatible with SEPARATORS . Dish Pro Plus is the latest generation of DISH LNBs and is compatible with separators.
Directv up to this year has used the Equivalent of DISH Legacy LNBs. This year they introduced the SWM (actually information was released last year) this makes it possible to actually use splitters to feed the dual tuner receivers with a single cable. SWM is coming into national availability but is not the predominant technology.
Current Directv New Customer Deal
DVR Problem - Gray Screen
