DishPro Plus 44 Switch Review | Page 5 | SatelliteGuys.US
Good question gowfo - and people probably get pissed off at me for being 100% nit-picky about the terminology all the time - but this is why. :D
Thanks for asking guys...(sheesh.) No, I did not mix up the DPP Separator and a splitter.
Here is an update:
I *did* get the Separator to work. Here is how I had to do it on my system:
1) I hooked two feeds directly into the 921 with no Separator.
2) I ran a check switch. The 921 then became acquainted with the DPP44 switch.
3) I moved the feed to the 921 to port #2 (not the power inserter port) on the DPP44.
4) I replaced the Separator.
Mind you, I've heard from many people they have successfully used the Separator on port #1 on the DPP44 switch. It just doesn't work for me. It may be that I have the inserter at the switch rather than at the receiver, who knows...or my flash revision.
In any case, if I move it back to port #1, it won't boot (hangs).
I'm curious; All of you who have successfully used the DPP44 and a Separator on the 921... was your 921 already using the DPP44 prior to the use of the Separator?
gowfo said:
Hey Jsa_sf
Are you sure you have a separator and not a splitter, had a buddy scratching his head for a week trying to hook up a DPP44 to his 721 with a dish pro splitter. I stopped by to troubleshoot for him, and when I stopped laughing we got a Dish Pro Plus Separator ordered for him. :p
DPP Separator
DP Splitter
Yes, please - let us know where you started from and how you got it running.
Nope I went from a DP34 to the 44 switch. The seperator worked on the first shot on all my units.
From where I sit out of all the equipment I have used from Dish Network, this is the first one I can remember that worked as advertised out of the box. And for that I applaud Dish.
Others are reporting some problems but most have got it working, I am sure everyone install is a little different.
I really like my DPPP44 and may actually get another one so I can get rid of my legacy dish. :)
DPP44 and separator cable length limitation
There definitely seems to be a shorter-than-usual cable run length limitation if you use the separator. When I first hooked mine up, I had to place the separator near the switch to get it to work (my 921 is about 75' as the cable flies from the DPP44), when I placed the separator at the 921 end, no signal on tuner 2. I thought this may be because I am using existing RG59 wiring. So I went and bought some quad-shield RG6 and ran another line to the 921. Same result, separator at 921 end, no signal on tuner 2; separator at switch end, works fine.
Have Dish published any specs/notes about this? It seems that for the separator to be used as a solution to running more than 1 cable for a dual-tuner rcvr, the cable run from the separator must be fairly short (at least less than 75').
In answer to the other question, the first time my 921 saw the DPP44 switch was via the separator, so it seems you do not have to run a check switch without the separator first.
Cheers,
-Keith
Keith: I understand that you're reporting what you've observed, but it makes no sense that the separator would have to be close to the switch - UNLESS you've got bad cable. And of course, a requirement like that pretty much makes the separator worthless for it's intended purpose of saving extra cable runs.
75 feet should not be an issue unless there's more than 125 feet from the switch to the dish. DishPro spec is for 200' maximum end-to-end.
There's effectively NO 'electrical' difference in the signals sent from the DPP44 when the separator is used vs. when it's not. That is, the DPP44 is sending 2 bands of satellite data - the only difference is regular DishPro is always 1 satellite, odd & even and DP+ can be either odd or even of either one or two satellites. In fact, both bands might even be the same stream!
I understand the rationale, but how else do you explain this?
If I setup:
DPP44 - single 75' run - separator - 921
I get a good connection but no signal on tuner 2 @ the 921. Tuner 1 is ok.
If I setup:
DPP44 - separator - dual 75' runs - 921
everything works fine.
I see the same results with both my existing RG59 and brand new RG6 cable.
I would love for this to work!!
Thanks,
-Keith
Well, all I can think of has to do with some reports that the separator is sometimes not happy being on the DPP44's port 1 (with the power inserter).
Other than that, my only other thought is a bad jumper - but you've undoubtedly checked all that.
Hmmm... My insticts tell me there is a common denomenator here.
When I initially set my separator up, I was actually running 1.85. I knew it probably wouldn't work, but I figured what the heck, and plugged it all in right into the power inserter and port 1.
The 921 *did* boot, and it obviously didn't recognize the 44 switch... Yet it was showing channels from 119 without a problem. I ran the check switch just to see what it would do (before beginning the download of 1.86) and it indicated that tuner #2 wasn't connected to a switch.
Now, of course, after the 921 had 1.86, I had all my problems where it wouldn't boot unless i hooked in two feeds directly... Once I ran the check switch, and the DPP44 was recognized, I was able to get it working with port #2, 3 or 4. In my case, it's a short run though... So I don't think it's a distance issue.
Perhaps on the occasion that people have problems using port #1 on the 44 switch with a separator on the 921, it specifically is the lack of tuner #2... maybe the power inserter (this is without ANY understanding of how these things work so grain of salt here) somehow would interfere or impede on the 2nd tuner signal coming from the 44 switch under certain conditions...
I'm stretching here.
I have tried all ports.
Indeed - I've checked all the cables/jumpers on other connections with no problems (including the new 75' length of RG6 I bought).
I am left to my original conclusion, something like there is more bandwidth required to run two tuners over 1 cable, and hence the effect of signal loss causes practical limits to be reached over a shorter distance of cable.
This is empirical, I have not measured anything. But I cannot think of any other variable which can explain the behaviour I am seeing. Apart from where the separator is placed, all the other pieces of the equation are constant. If anyone is interested enough, please bring your oscilloscope and come visit me in the beautiful wine country of Sonoma County CA so we can get to the bottom of this :)
Those of you running the DPP44 plus separator, what roughly is the cable length between the switch and the separator?
Thanks,
-Keith
No, the bandwidth required to run DishPro vs. DishProPlus is exactly the same.
There's gotta be something going on that we're just not seeing.
That's not what I'm saying. The issue is running the feed over 1 long cable vs over 2 long cables.
After reading some more it seems that the separator (perhaps) splits the signal into a low-freq band, and a high-freq band. If so, *after* the separator, each cable carries a narrower frequency range.
With the separator at the rcvr, 75' from the switch, one cable has to carry the full frequency range (x) over a long distance. Whereas with the separator at the switch, two cables each carry a narrower frequency range over the same distance.
Is it not possible that (assuming I have crap RG6 or something), the 2nd scenario (separator at the switch) might work whereas the 1st one doesn't because x/2 is "easier" on the cable than x/1, for the same cable length?
I am no electronics engineer so this may be complete hogwash. But I'm just trying to figure out the cause since the effect is repeatable every time I move the separator position.
If it is hogwash, got another idea?
Thanks,
-Keith
Your logic is reasonable, I just don't think it actually applies here.
One way to find out - take the 2 long feeds and plug each into a DPP44 port - NO separator. This forces EACH cable to carry a full 2-band load. Under standard DP "rules" the Even transponders will be on the upper band no matter what.
If it works, the (long) cables are NOT part of the problem, and your hypothesis fails.
If it does NOT work on ONE side, try using the OTHER side for the long feeder to the separator and see what happens.
Again, ANY idea here is worth exploring, beause this is a strange one for sure!
Is the 75-foot cable you're using to feed TV1 in the "at-switch" scenario the same one feeding the separator in the "at-receiver" scenario? If so, that cable may be your problem.
The cable feeding TV1 is at a lower frequency (950-1450 MHz) than the one feeding TV2 (1650-2150 MHz); meanwhile, the cable feeding the separator handles both ranges. The higher the frequency, the harder it is to get it thru the cable. If the cable isn't rated for 2150 MHz, it may work for a separator-to-TV1 feed; but it won't work for switch-to-separator or separator-to-TV2.
Yes, at first it was. When I first tried this, I was using an already installed RG59 cable for the at-receiver scenario, with two 1' radio-shack RG6 patch cables from the separator to the rcvr. That failed as described.
I then tried the at-switch scenario with the same cable for the satellite 1 input on the 921, and another already installed RG59 cable for the satellite 2 input on the 921, with one of the same 1' RG6 patch cables between the switch and the separator. This worked fine.
Since my curiosity was now piqued and assuming it was the RG59 that was the problem, I went out and bought a 100' length of radio-shack gold quad-shield RG6, which I cut to about 75' and then used for the at-receiver scenario instead of the already installed RG59. This also failed as described.
To test the cables I ran both the 1' RG6 patch cables and the 75' RG6 cable into a feed from the DPP44 to a 301 rcvr, which continued to work fine. This must mean that the 75' RG6 cable is able to successfully carry a full-frequency DPP signal must it not? If so then my hypothesis must be wrong, unless if the signal is marginal, perhaps the insertion of the separator itself is enough to drop the signal below some threshold?
Is it possible that this is something to do with the 921 itself and the check-switch function? I can't see how though, I go through the same process each time, and surely to the 921 it looks the same no matter which end the separator is at?
Thanks,
-Keith
I think this is moot since I have tried the new 75' RG6 cable with another receiver and it worked fine, which should mean the cable is able to carry the full frequency load right? Yet it still did not work with this cable and the separator in the at-receiver scenario.
Bizarre.
Thanks,
-Keith
Yes. Quite bizarre. I wonder if DP+ equipment actually does not do band-stacking when it's not needed. That would of course ease cabling issues.
Dunno - guess we've just got to build a matrix of the Check Switch results.
As an installer, I've gotta know what type of fittings you used when you cut the Radio Shack cable from 100' to 75'? Please tell me you didn't use those twist on connectors with DP equipment - if I had $10 everytime I rolled up to someones trouble call and relaced those fittings, I could retire for a year! I prefer PPC compression fittings (Gilberts are OK but sometimes won't test for "fire" when checking for a signal with a small tester).
Have you tried running one length of cable straight from the DPP44 to the receiver area (through a window maybe for testing purposes); hook in the separator then use your 2 two foot jumpers to the 921? 75'...100'...doesn't matter at this point. Is all the cable swept tested for 2150? It MUST be at this rating. Doing this will bypass (temporarilily) any other problems that may exist such as a bad ground block, a wall plate with a low rated barrel, bad cables, crappy fittings, etc... IF you do this and still have a problem then...well, I'm stumped too. I don't see it as being the receiver as you can put the separator a foot away from the 44 and it works!
The best conclusion I can come up with given that the 75' of RG6 works fine with no separator and a 301, is that the signal strength for the upper frequency band is low by the time it gets to the end of the cable, and is insufficient to overcome the additional loss introduced by the separator. This is not a problem when the separator is at the switch because the incoming signal is strong.
I guess this could be a bad separator, or poor RG6, or it could be neither of these things and simply a limitation of using a separator with long runs of cable.
If you have a separator working fine at the end of a 50' plus cable run, please post here!
Thanks for all the input,
-Keith
942 main tv - backfeed all others on tv2? (newbie setup questions)
Anyone Had Success At Cascading a DPP44 with a DP34?
Users Who Are Viewing This Thread (Total: 5, Members: 0, Guests: 5)
