Dishnetwork Camper | Page 2 | SatelliteGuys.US
Dishnetwork Camper
Infospecs. See my previous post. Using your distributed feed you should be able to make that work for you. If you have a DVD player and a video controller that allows you to send the DVD to a rear TV, it should also allow you to send Sat to the rear TV.
Well it turns out that my lnb is only the DPlus, not the Dplus Pro. Now the question is: a: can I run the 2nd sat feed through a diplexer? B; can I get an external seperator to run the 2 coax feeds into. c, would it be easier to just buy the Dish Pro Plus lnb?
thanks
I think your best bet would be to buy the Dishpro Plus twin lnb. You already have everything else you need and you can usually pick used lnb's up on ebay pretty cheap.
922 soon?
Dish and Freedom Corp disagreement heats up
