Dish Pro Plus Question | SatelliteGuys.US
RickRand
2
I have a dish 500 with a DPP installed on it. I also have a spare DPP. My question is, is it possible to use a 4 lnb yoke to connected two DPPs to one dish 500? or would i have to use 4 seperate single lnbs for said yoke? thanks!
The Dish 500 is engineered for 2 LNBs. If you tried to put 4 LNBs on it, at least two of them would be in the wrong position, and your signal strength would suffer. It is possible to "hit" more than 2 orbital locations with bigger dishes; the Dish 1000 series are examples of that.
What is it you are trying to do? If you want to feed more than 2 receivers, there are DP quad LNBs and DP (and DPP) switches.
Remote vs Samsung vs VIP22DVR
Very newbie question on a 522 Dual receiver
