I just did it. I put it on there with all the bolts. The bolt pattern is identical. The signal just sucked.dodge said:the pan off a 1000 will not fit on a 500 and vice versa, the bolt holes dont line up...
ralfyguy said:What is the dimensions of the pan of a superdish?
inwo said:24 X 34.5 The focal length is way different. As is the F/D and thus "twin lnb" spacing will not work.
Iceberg said:I thought the SD was 36x20?
Limited time offer
