dish packages question | SatelliteGuys.US
fdwhacker
Winner, SD
Hi, I would like to get DishNetwork, and I'm wondering if I can get just the local channels or if I have to add them to another package. I looked at other posts but I couldn't decide whether I can or not. Any help would be great!
As boba said, if you own the receivers, you can get a locals/access only pkg f/$10, which I have. It combines the locals pkg + the $6 access fee f/accounts w/out an AT/DL pkg.
There is also a $10 welcome pkg, with about 15+ basic channels (do a search for the list of them here), which you can add locals to it f/$5.
Once you get either one of these pkgs, you can add other a la carte channels to them, as well as add the FREE PI pkg.
Dish sells a DTVPal DVR that can pick up local antenna broadcasts without a monthly subscription. Do you have local stations worth picking up or did you already look down that avenue? You probably don't get all the ones you'd like in SD.
ViP Restarting and shutting down
Need to play or recode dish .tsp files - very weird problem
