Dish OTA Antenna Install Question? | SatelliteGuys.US
charlesrshell
SatelliteGuys Crazy
11,256
5,985
O'Fallon, IL
Does anyone know where Dish will install the $49.99 OTA antenna? Will they install on the Dish antenna mount? Or will they search for the strongest signal and install in that location separate from the satellete antenna (wall, eve, soffit mount, etc)? Is the antenna still going to be a Winegard with the Dish logo on it? Thanks for all responses.
I have heard so many stories on this. All I can say is that I would not trust a Dish installer to know anything about OTA. If the antenna is a Winegard or a Dish branded Squareshooter (I have heard both so I don't know if it is either one or if it is just a clip on) They will probably put the thing up as close to the Dish as possible. If it works great if it don't oh well.
Again I would not expect much for 49.99.
622 and Tivo - need help!
Activate 622?
