Dish Network Advanced Technical Support....Total Failure | Page 2 | SatelliteGuys.US
Did as you suggested Lucky86. There are additional listings for Starz HD channels in the 5500 and 9000 range but respond with the same error when selected. Ran the Check switch with alternate checked and 110 and 119 checked green while 129 checked yellow. My 129 dish is a 1.2 meter.
Thanks for the advice, but still blacked out. I will probably ponder a move to Direct TV. Not sure if that is any better I am not real pleased just now with Dish.
WIX
Did you contact a Dirt member?
Did you read step 3?
3. Once you have succesfully completed step 2, the receiver box will start removing the 129 conus channels AFTER the next nightly update.
I would let it update tonight to see if that helps.
Thanks Lucky86,
It's 5:45 PM here now I will recheck after the Friday morning updates. I got a PM from a Dish person so I will respond to that after I dig up my account number.
WIX
Aloha Lucky,
You score the Bingo here. All HD Starz channels are viewable after the morning update. Nice Job.
WIX
WD External DVR
Control AppleTV with Dish 40.0 remote?
