Dish Motor Rec | SatelliteGuys.US
Dish Motor Rec
smata67
118
I have read the SG2100 reviews and this seems like the best value for my 36" Fortec Star/Coolsat combo. Are there any other units out there that I should consider? The SG2100 reviews are almost a year old, how are these holding up?
Bear in mind that the SG2100 is the only positioner with a manual East/West switch on the motor itself - it makes installation a whole lot easier.
Everyone seems to own the SG2100, can't argue with the numbers.
Cascade said:
Bear in mind that the SG2100 is the only positioner with a manual East/West switch on the motor itself - it makes installation a whole lot easier..
Cascade
The Satcontrol SM3D12 also has manual East / West switches on the bottom of the motor.
Sadoun said:
Cascade
Cascade, I have this motor and agree with this statement, it does have manual East/West switches on it.
Saboun;
In regards to the SM3D12 motor, is there any hard motor limits that would limit its movement, it appears to not move as far as advertised in the manual? I am at long 75 degrees. I should be able to make it over to 123W, however, when I have the ARC dialed in, I am unable to get past 121W.
Rick
Quick! Do I want this system? C Band/KU
Secret to catching more transponders on scans
