Dish Elevation- I'm Confused! | Page 2 | SatelliteGuys.US
more help
if you can not hit the 61.5 the 1000.4 will not work as it still is pionting @ the 61.5 put up a 1000.2 and pull in hd off the 129 it has a higher elavation.
That's quite the dish garden growing there. :up
that doesnt include the 2 on the roof either :D
no WAF because no W ;)
have a HOA to deal with but being the president of the HOA has its advantages.....but then again the rule says "on the edge of the roof or the deck" and I'm following the rules :D
dish and direct both use off-set focus dishes, the offset is exactly 22.5 degrees. a prime focus dish puts the lnb right in the path of the signal, and an offset dish gets the lnb out of the way of the signal
522 Auto tuning problem
Trying to find 119 but 118 takes over!
