Ray must be busy, I PM'd him 1.5 ago hours still no response ???????????????????
If you go back to the main forum page, and scroll all the way to the bottom, you can see which DIRT members are online at the moment. They are highlighted in RED.
Thanks for the reply, I do not think Dish had anything to do with Speed Channels demise. But if you are a Nascar fan you should know that Fox sports 1 HD and Fox Sports 2 sd ,try to replace Speed. So I thought it would have been nice if these 2 channel would be in the AT200 package where speed was,
Well anyhow got finally got Ray and Hopper :"HWS" is to be installed Sat. And EA dish to replace my wing setup.
You might want to connect an antenna to it or it won't find any channels.Yep, you plug it in, the Hopper will reboot, and there you are. Next, all you need to do is to scan for channels. Menu, Settings, Diagnostics, Over The Air, Scan.....
Also, position it so that the antenna coax won't be pulling on the USB and unplugging it from the Hopper.
Limited time offer
