DISH and cable in the same room.... | SatelliteGuys.US
jeremyburns007
47
Is it possible to run a DISH signal and a cable signal through the same coax? Has anyone tried this? It would be a lot easier than running another piece of coax to that room.......any advice would be appreciated.
No, it's not difficult. If you have HSI with your cable company, you must buy diplexers rated 5-2200 Mhz. Don't buy the ones rated 40-2200 Mhz. The upstream frequency is usually below 40 Mhz so it won't work.
Dost it cost to move service?
Need 2 dishes to get voom?
