dish alignment help | SatelliteGuys.US
dish alignment help
htownjoe
163
splendora tx
hi guys, i just hooked up my bud to a chaparral monterey 55 and during setup i set the east limit at around the 70 degree mark, problem is when i went to the west the dish started pointed low at about the 115 mark, the dish is set right on the pole and is level, and the dish is moving well. can someone help me out.
This is a good link to learn how to setup and track your dish:
http://www.geo-orbit.org/sizepgs/tuningp4.html#anchor797917
If the dish is too low when looking at the western satellites, the dish needs to spin to the west (assuming the elevation and declination settings are correct). the elevation for the Houston area should be 30.5 degrees and the declination angle should be 35 degrees (when the dish is centered and not leaning east or west). On the Unimesh, you can measure that on the mounting ring.
Disney analog took off
Analogue NTSC Polarity
