Titanium Satellite - Dish actuator | SatelliteGuys.US
Titanium Satellite Dish actuator
I picked up a ASC-1 about a month ago and it's built like a tank. You can tell by it's weight alone it's not a plastic tinker-toy with a tiny transformer. Glad I bought it.
so is the remote IR.
also guys i just purchased a 4ft ku band dish. any recommandations on a lnb.
about the LNB, if you only need Standard 11.7-12.2 GHz, I recommend the Maverick MK1-PLL
MK1PLL
If you want a universal LNBF (so that you can also receive lower Ku 10.7-11.7 GHz, for example if you are in the coverage zone of 34.5W), I recommend the GeoSatPro UL1-PLL.
Those LNBFs are very reasonably priced and are great quality
OTHER Recently bought
OTHER looking for a recommendation for FTA receiver
