P palacios302 Member Original poster Apr 8, 2004 9 0 Apr 8, 2004 #1 Hello newb here. Just a quick question. How do I download the latest software to my 811 receiver. Thanks
gvsurn SatelliteGuys Family Feb 5, 2004 42 0 Caledonia, MI Apr 8, 2004 #2 did you just get the receiver???
P palacios302 Member Original poster Apr 8, 2004 9 0 Apr 8, 2004 #3 No. I have had it since early Jan.
P palacios302 Member Original poster Apr 8, 2004 9 0 Apr 8, 2004 #4 By the way I have software version 262.
gvsurn SatelliteGuys Family Feb 5, 2004 42 0 Caledonia, MI Apr 8, 2004 #5 it will download it automatically.... you can see if any upgrades are available buy going to the menu then choice 6 then choice 4. the current version is 265
gvsurn SatelliteGuys Family Feb 5, 2004 42 0 Caledonia, MI Apr 8, 2004 #6 menu then 6 then 1 then 2, choose download automatically
Bobby Publican Supporting Founder Lifetime Supporter Sep 7, 2003 72,899 30,181 Rohnert Park, CA Apr 8, 2004 #7 And then, turn the 811 off with your remote for 15 minutes. It will then automatically download the latest software.
P palacios302 Member Original poster Apr 8, 2004 9 0 Apr 8, 2004 #8 I checked upgrades available, and it says none are available.
gvsurn SatelliteGuys Family Feb 5, 2004 42 0 Caledonia, MI Apr 8, 2004 #9 did you check to see if you have the upgrades automatically or does it have to ask you????
gvsurn SatelliteGuys Family Feb 5, 2004 42 0 Caledonia, MI Apr 8, 2004 #10 choose auto then shut it off for 15 mins
P palacios302 Member Original poster Apr 8, 2004 9 0 Apr 8, 2004 #11 Do I have to unplug the 811 or just turn off with remote? Also I setup the 811 to download without permission. Is this correct?
P palacios302 Member Original poster Apr 8, 2004 9 0 Apr 9, 2004 #13 Turn offed 811 for 15 minutes, still have same software. When I turn on it just gets "acquring signal" nothing else
gvsurn SatelliteGuys Family Feb 5, 2004 42 0 Caledonia, MI Apr 9, 2004 #14 i got my 811 after the first software upgrade and all i did was exactly what you did. you can try unplugging it.
P palacios302 Member Original poster Apr 8, 2004 9 0 Apr 9, 2004 #15 I unplugged the 811 re plugged, liet it sit and I still have the same software. This sucks
gvsurn SatelliteGuys Family Feb 5, 2004 42 0 Caledonia, MI Apr 9, 2004 #16 call dish, see what they say
P palacios302 Member Original poster Apr 8, 2004 9 0 Apr 9, 2004 #17 I will call them in the morning thanks everybody.
