That means that you will keep it?I got it last night on my 922. Can now do tv 2 independently. Now it operates like the 722k does.
More like the Logitech Revue perchance?And if it does it will be a much different product that was shown at CES.
i have the vip 922I got it last night on my 922. Can now do tv 2 independently. Now it operates like the 722k does.
i have the vip 922
do you have a second remote to control the tv2?
my second tv is working but i cannot change channels.
thank you
I was able to delete the unwanted but theere are still multiple instances of some of the channels I want. However, only one instance shows up in the All Available Guide. We'll see after tonight's update and reboot.I got it this morning. It seems faster to remote control commands. One thing that still is not fixed, or perhaps I am the only one, is the problem with deleting channels that you do not want from the OTA tuner. Does anyone else have this problem? When you scan for OTA channels and it gives you the list of what it finds, if you go through and delete some, it will take you back to the top and all of the ones that you deleted will be back. Sometimes it adds duplicates. Has anyone else experienced this?
That means that you will keep it?![]()
i have the vip 922
thank you
Yes I have a 2nd and 3rd remote for the master bedroom too. It works for tv 2 if you turn the number sign on the bottom of the remote control to show 2 in blue instead of 1 in green.
how would you change it at the bottom of the remote to show 2 instead of 1 and blue instead of green?thank you for any help
Of course you need a second remote! Amazon. 20 bucks
Limited time offer
