That what it says on the Dish Tech Portal. I think its right since I got it this morning.
So these software updates are in the Dish Tech Portal! Can you supply the link? Thanks Darrell
As always not all receivers are affected but I've read reports about problems with HDMI, EHD and play back from even the internal hard drive. I personally have problems with the 622 and the EHD playback, no problems with the 722. That's why I'm surprise it went out to all receivers.
Just hoping there's a new update coming soon.
Here is the link:
Tech Portal : Tech Updates
We used to go by what the Tech Portal posted but many times they didn't spool the updates so it's not 100% accurate.
Yes. But I have no disire to use it.I got 4.49 on my 2nd 622 the other day and it is now on both. Strange thing is the Guide pop-up is not on both 622s. The 2nd one does not have it. I've gone through the hard boot and no luck. Is anyone else seeing this?
Go to the favorites setup screen and you can turn it on or off.I got 4.49 on my 2nd 622 the other day and it is now on both. Strange thing is the Guide pop-up is not on both 622s. The 2nd one does not have it. I've gone through the hard boot and no luck. Is anyone else seeing this?
I have problems on one of my 722s loosing previously set weekly timers for some reason. I mean, the timers are still there but they didn't schedule themselfs. So I deleted them and re-did them. They worked then. Also, my favorites list got wiped out for two of my 722s.
Limited time offer
