Dish 222K over scanning on guide | SatelliteGuys.US
Claude Greiner
13,213
3,776
Detroit - The Paris of the Midwest
Got a 222K connected Via HDMI to a Panasonic TV, and its over scanning when I go to the guide.
If you look on the left side, you can see half the channel numbers chopped off.
Any ideas?
I tried changing resolutions and aspect rations and nothing seems to help.
I would set the resolution to that of the TV and aspect ratio/zoom level to normal on both. If you did that, and I presume you did, then there has got to be an overscan setting on the Panasonic that you need to locate and correct. If there is no such setting, then one or the other has got to be defective.
Now if he had a Hopper (LOL), he could change the position, zoom, etc. by Yellow, Format TV, Screen Adjustments, then up, down, left, right, magnify, or shrink and close. It gets the grid to fit as needed, easy peasy (did I say that?).
-Ken
I would first look at the zoom setting of the TV - could be set to wide or theatre zoom or something like that. (If you already have not)
H2K audio problem with skip or pause
Dish question from Dish newbie
