Dish 1000 plus help please | Page 2 | SatelliteGuys.US
You could try peaking on TP8 for 129 and see if you get better signal readings. You could have someone look at the TV screen and you can just nudge up and down and left and right without unbolting anything, just to see if you can improve the signal strength. That way you'll know which way to go.
DPP44 and FSS sats require the FSS bird to be the LAST port on the switch. I had the same issue with my SuperDish 121. 121 is FSS and feeds port 4 of the DPP44. My order was: 110, 119, 61.5 (from a Dish300) and 121.
Works like a champ.
How to get a promotional rate?
Help...I gotta problem!
