Dish 1000.2 system No 110 signal ? | SatelliteGuys.US
gilmour55
2
I just purchased a Dish 1000.2 system with a triple LNB. I have two coax lines installed (left from my Dish 500) but I am only using one of the two as per the dish setup instructions. The single coax is connected from the LNB port 1 to the DPP separator and then from the separator to my 622 receiver thru (2) 6" pigtails. When I run the check switch test:
Port 1 says 129, ok.
Port 2 says 119, o.k.
Port 3 says "conn", "x".
In the instructions port 1 is 119, port 2 is 110 and port 3 is 129 ?
I am able to receive both the 119 and 129 signals at 96-98% but no 110 signal at all ? Any suggestions ?
You need to repeak the dish. You have 129 on the 119 eye and 119 on the 110 eye. You need to swing it to the East or to your left (if standing behind the dish). Then you run check switch.
Yeah swing the dish to left and raise the elevation a little.
Oh and BTW gilmour55....... :welcome to SatelliteGuys!!!!!!!!!!!!!!!!
Hd Channels 436 & 386
Problems With TBS HD
