Directv multiswitches and splitters | SatelliteGuys.US
johnny58259
190
I have an H24 and 2 H23 HD receivers. Does directv still make a multiswitch compatable with these receivers that you can run a atenna feed into the switch to get the extra local channels? I remember on the older receivers they did you would hook the atenna up to the multiswitch and put a diplexer at each tv so you would have one feed for atenna and one for sat. If they make a multiswitch for this what's the model #. Thanks
You can diplex with a Swm8 as long as you aren't using whole home DVr (MRV). MRV cant be diplexed as the signal range overlaps.
He's not using it. He don't have an HDDVR ;)
DirecTV CEO Sees 'Logic' in a Merger with Dish Network
DirectTV everywhere on iOS question
