Direcpc LNB | SatelliteGuys.US
Direcpc LNB
john green
736
Georgia
For those of you who were curious about the LNB that came with the Direcpc dish here are some pics.
Yes John, that LNB is different from mine. Mine is square, not round. Glad you lucked up and got one that can switch polarity via voltage. Thanks for the pics!
John
What size is that dish? I have a 32x18 that has the same LNB....my 39x23 has a rectangle one (7720 probably has the same one)
oh wait...your right...35x20...same size as a Superdish
I'll get a picture of the other LNB for the larger dishes
My p* 39" has the same feed horn, but has outputs for both h and v. Since its set on amc3 for PBS , I just use 1 of the outputs.
I just thought I would post some pics of my LNB (off of a Direcway Dish).
If anyone has any idea of the specs please feel free to chime in.
The first picture is of the label (attached to the LNB)
The second picture is of the LNB (minus the cover)
The 3rd picture is of the entire dish
PS I kinda guessed when I put the specs in my sig
Still got 2 off them here! Standard 10750 for the L.O. (As stated above)
That's one hell of a bend/bind you have the cable doing the first set of pictures... or maybe it's the angle you are at with the camera.
If your referring to my pictures its because the one with the LNB was taken upside down and flipped in software. The cable's look to be really messed up but they are not in real life :D
Can I squeeze more rotation out of my Stab HH100?
Pansat and Dp switches
