Digiwave HD9003PVR | SatelliteGuys.US
Digiwave HD9003PVR
wallyhts
Staff member
HERE TO HELP YOU!
3,219
448
Digiwave HD9003PVR is a HDTV Digital Satellite Receiver implemented with many functions, it can be store 5000 or more channels and resolution can also be up to 1080p, it can be also support many different file format for video, audio and image, his multi-language OSD function also gives better experience with different user, compact size also save your space and really easy for installation.
Features:
- 5000 or more channels memory space
- Fully compliant with DVB-S/S2 standard
- VC-1 MP@HL and AP@L3, up to 1080p@30fps
- Audio decoder compliant with MPEG1, MPEG2(Layer I/II), MP3, WMA, AAC-LC
- Simultaneous supporting HE-ACC decoding and transcoding to AC-3
- HDMI 1.3 transmitter output interface with embedded or external HDCP key
- Resolution uo to 1080p@60Hz
- Multi-language OSD supported
- Multi-language audio and subtitle reception
- PVR function supported, recording TV and playback media files with external storage
- Supports pictures with JPEG, BMP, PNG
- Supports music files with WMA, MP3, AAC(.wma, .mp3, .m4a)
- Supports movie files with MPEG1/MPEG2/MPEG4/H264/VC-1
- Capable to playing picture and music at the same time
- Advanced Time-shift function with external HDD/USE stick
- Software upgrade by USB2.0 interface
Specifications:
TRANSMISSION STANDARDS
- DVB-S2/S, MPEG-2, MPEG-4, H.264
SATELLITE INPUT/DEMODULATION
- Connection Type: 1xF Type(1 Input), Optional for Loop Through
- Input Frequency: 950 to 2150 MHz
- Signal Input Level: -65 to 25 dBm
- Band Switch Control: 22KHz
- LNB Supply: 13.5V/18.5V, max 350mA
- Demodulation: QPSK, 8PSK, 16APSK, 32APSK, compliant with DVB-S/S2 spec
- Symbol Rate: 2<Rs<45 Mband(SCPC/MCPC)
AV OUTPUT INTERFACE
- Video Output: HDMI, SCART for RGB/CVBS or RCA for CVBS/YPbPr
- Audio Output: Stereo Audio L/R output interface by SCART or RCA, S/PDIF coaxial output interface
AUDIO/VIDEO PROCESSING
- Video decompression: MPEG-2 MP@HL, MPEG-4 SP and ASP, ITU-T H.264 MP&HP@L4.1, VC-1 MP@HL and AP@L3, up to 1080p@30fps; Option for RealMedia Decoder, up to 720p@30fps; HW JPEG decoding
- Resolving rate: PAL-25 frame@720*576 and NTSC-30 frame@720*480 for CVBS output, 1080p/1080i/720p/576p/480p/576i/480i for YPbPr/RGB component output, HDMI up to 1080p@60Hz
- Signal compatability: Support conversion for different video formats
- Video data rate: Up to 108Mbps
- Video Format: 4:3, 16:9, By Pan & Scan and Letter Box conversion
- Audio decompression: MPEG-1, MPEG-2(Layer I/II), MP3, WMA, AAC-LC, Optional for AC-3, E-AV-3 and HE-AAC 5.1 multi-channel decoding
- Audio output mode: Stereo, Joint stereo, Mono, Dual Mono, HDMI or SPDIF audio for PCM or RAW
DATA SERVICE PORT
- Connector: USB
- USB2.0 interface
MEDIA FEATURES
- Picture: JPEG, BMP, PNG
- Music: WMA, MP3, AAC (.wma, .mp3, m4a)
- Movie: MPEG1/MPEG2/MPEG4/H264/VC-1/Motion JPEG(.flv/.avi/.mpg/.dat/.vob/.mov/.mkv/.mjpeg/.ts/.trp)
- File Management System: NTFS, FAT32, FAT16, rename, delete operation supported
POWER SUPPLY
- Type: AC mode
- Main input voltage: 100 - 240V AC @ 50Hz/60Hz
- Power consumption: Max 15W, Standby <0.5W(option for Green power)
- Insulation resistance: More than 10MR at 500Vdc, Ambient conditions of 28% & 70%RH
- Standby Voltage: I/p yo O/p:3kV(1 min)
- Temperature Rise: <75 on winding & core; <50 on casting; At 264Vac @ 50Hz
- Safety Standard: Designed to meet IEC 9
MICROPROCESSOR
- Microprocessor: Mstar MSD7816(MIPS34K CPU with target speed 550M built in)
- Flash: 4Mbyte
- SDRAM Memory: 64Mbyte
PHYSICAL CHARACTERISTIC
Front Panel
- Keys: 3 Key for Power On/Off, Up, Down
- Indicators: Optional for LED Indicator for Power On/Off
- Remote Control Input: Infra-red reciever
- Display: 4 Digits 7-segment LED display
- Connection: 1xUSB2.0 interface
Rear Panel
- Connections: F-Type, RCA, HDMI, S/PDIF
Looking for a nice review of this once you get it hooked up.
Not much bigger than the remote, is it? haha Waiting for your review, put it through its paces! Find one of those 29270SR feeds tonight and see if it works properly.
No serial port, I wonder if it has a TTL header for rescue operations if ever necessary.
Not sure will have to check when i pop the top.
Unit was in PAL mode "BOO"
The remote is like the geosatpro expect it seems to be a flat black color and not the marble black and the power button does not light up.
What's the blind scan speed like?
4:2:2 not sure yet. Price I would guess around $100-$120
Last night I noticed they were on Amazon Canada (only) for $139 Canadian. The more advanced unit that incorporates a network media player was like $379 Canadian if I remember rightly.
Not bad. (Only 2 scans as of now)
3:27 to scan 87 C-Band
Dam that's crazy high if u ask me.
About the same as an AZbox or the Optibox Raptor, which have similar functions. (But there are other boxes from Optibox, plus the Spark 7162 line such as the Amiko Alien2, which are cheaper.)
The thing I don't know about the media player model is what OS it runs.
Please let us know if the Digiwave displays 4:2:2 properly.
Here's the other box it runs Linux so I hope I can get SSH access.
Satav aka Brian is right like normal. No 4:2:2 Boo.
It sounded too good to be true. Lol
Digiwave is well known over here to lie in the specs of their products in order to make them better than what they really are. This is why I told you in the other thread to not get your hopes up about these receivers supporting 4.2.2. Up until I complained several times, they were selling their 85cm x 93cm dish as 39" but this is actually only a 36 inch dish as a 39" dish would be 90cm x 99cm.
Regards,
PwrSurge
pwrsurge said:
Digiwave is well known over here to lie in the specs of their products so that's why I told you in the other thread to not get your hopes up. Up until I complained several times, they were selling a 85cm x 93cm dish as a 39" dish but this is actually only a 36 inch dish.
Regards,
PwrSurge
Can't wait to see what they say. Got to love people who lie. I asked them 3 times and the last time I sent the post that satav made and the manager replied and said it would decode CBS 4:2:2
I don't want to burn a bridge with them but I hate when people lie to get a sale.
Iceberg said:
what channel did you try?
I know Daystar on 101W C-Band is 4:2:2
CBS c-band 89 (Audio is coming thur)
36" KU dish and a 6' dish need a new home
update on slimline with superdish mod.
